i need BAR connect
Old Aug 25, 2009 | 07:41 PM
[eg6]'s Avatar
Default i need BAR connect
seen these around back in the day but do they still exsist? cuz i could use one!!!! tried to BAR a jdm b16 back when u still could in an EG and i failed SEVERAL times so i would like to BAR a b18c1 this time anyhelp would be great! by the way if it can say JRSC aswell that would be even better PM me if u have more info thanks!
Old Aug 25, 2009 | 08:23 PM
Szandor1966's Avatar
Default Re: i need BAR connect
good luck just do it right much easier
Old Aug 25, 2009 | 08:44 PM
Linh.'s Avatar
Is there really such thing as BAR connect?
Old Aug 26, 2009 | 10:32 AM
bluebomber's Avatar
Information Leafblower
B18C1 should be no problem as long as the year of the engine is the same as or newer than the car, everything is hooked up correctly, and you have C.A.R.B. stickers for any parts that are aftermarket. The JRSC should be fine, because IIRC it was C.A.R.B. legal. Again, make sure you have the stickers. If you don't, call the manufacturer and ask them.
You won't need a "connect" as long as you do it the right way.
Old Aug 26, 2009 | 11:43 PM
fourthgenhatchB17's Avatar
VERY doubtful, but if there is one, you wont find one on HT that will respond to this thread, lol.
Old Aug 27, 2009 | 02:16 AM
xander1100's Avatar
just walk into your local shop with a Franklin...jk, as long as you have the right stickers you should be fine
Old Aug 27, 2009 | 09:45 AM
[eg6]'s Avatar
Pm's my friend Pms thanks for all the advice i believe i found what i needed.
canduvtec
May 27, 2013 06:22 AM
hard_boiled_EG
Southern California
Apr 5, 2009 11:15 PM
Super Trooper
12
Mar 10, 2007 03:56 PM
EricUSC
May 22, 2003 12:15 PM
PezRacer
Apr 14, 2002 08:17 PM
