Does open headers add HP?
Old Aug 16, 2009 | 08:20 PM
notsoslow's Avatar
Default Does open headers add HP?
does open headers add more HP then having an after market exhaust?
i just need a yes or a no.
Old Aug 17, 2009 | 12:33 AM
delsolproblems's Avatar
Default Re: Does open headers add HP?
The answer won't just be yes or no. Usually an open exhaust decreases low rpm power and increases top end power. There's a perfect amount of backpressure that makes the most power at a given rpm.
Old Aug 17, 2009 | 05:12 AM
ddd4114's Avatar
Backpressure decreases power. Velocity and length tuning are what you're thinking of.
Old Aug 17, 2009 | 05:35 AM
civicgsr's Avatar
Sport Compact Car had an EG with a B16a. They talked about huge HP and torque gains from low rpms to redline with an open race header.
I had similar results when I did a header, test pipe and 3" exaust on the 240SX that I had. Good solid gains everywhere.
Old Aug 17, 2009 | 06:06 AM
civic-one's Avatar
try this https://honda-tech.com/forums/tech-misc-15/disadvantages-advantages-open-headers-2570101/
Old Aug 17, 2009 | 06:21 AM
civicgsr's Avatar
Originally Posted by civic-one
Other than a couple of good posts, it's full of old bad myths. The only disadvantage to an open header is that it is wickedly loud.
Old Aug 17, 2009 | 06:22 AM
civicgsr's Avatar
Yes
Old Aug 17, 2009 | 11:44 AM
notsoslow's Avatar
thank you
Old Aug 17, 2009 | 02:04 PM
Scott_Tucker's Avatar
This thread has been argued a million times. The bottom line is nobody can tell you whether or not your combination of parts will make more power with or without an exhaust so anybodies guess is just that - a guess.
Old Aug 17, 2009 | 03:06 PM
civicgsr's Avatar
Why is it a guess when I've seen it confirmed more than once?
Old Aug 17, 2009 | 03:10 PM
ddd4114's Avatar
It depends on the engine, cam profiles, and the header.
Old Aug 17, 2009 | 03:20 PM
jhammond_82's Avatar
Reject Papi
put it on the dyno. 3 pulles for what, 75 bucks? do one without it, then two with, or whatever. then you be the judge as to how it helps, or doesn't.
Old Aug 17, 2009 | 03:40 PM
civicgsr's Avatar
Best Response, ever.
Old Aug 18, 2009 | 05:52 AM
The original poster supplied absolutely zero information about his build. That is why it is a guess.
TheRookie74
16
Jan 13, 2016 08:11 PM
rjvitec27
Sep 3, 2007 06:54 PM
ACR
Sep 23, 2003 02:02 PM
General Kills
Jan 3, 2003 09:41 PM
neonxrt
14
Dec 20, 2002 11:15 AM
