water temp sensor light still on.
Old Aug 18, 2009 | 03:53 PM
boosting101's Avatar
Default water temp sensor light still on.
still throwing cel #6..put a new single wire sensor in and and the 2 wire sensor both under the distrubtor i replaced and still throwing the code disconnecter the battery and still throwing the code
Old Aug 18, 2009 | 04:06 PM
street_ride14's Avatar
Default Re: water temp sensor light still on.
gotta ask .. did you check coolant level ?
Old Aug 18, 2009 | 04:11 PM
yes it has coolant. but didnt think that would be a issue anyway
Old Aug 18, 2009 | 04:18 PM
bumpp. any more ideas?
Old Aug 19, 2009 | 08:08 AM
dpetro1's Avatar
well if the sensor is known to be in good working order then you need to check the wiring, there may be a broken wire making the ecu think the sensor is not connected.
check for continuity with the ecu with an ohm meter
vtechjunkie
Oct 9, 2008 02:30 PM
BlueRex1020
11
Mar 23, 2007 08:06 PM
mycrx7
Jan 23, 2007 11:21 AM
folta2169
Jun 8, 2005 11:30 PM
BrokenHatch
12
May 31, 2005 05:26 PM
