need help!! idle problem after manifold install
Old Aug 11, 2009 | 05:24 PM
TopGear_'s Avatar
Default need help!! idle problem after manifold install
after installing the type-r intake mani and throttle body on my b16 the motor will rev to redline when cranked. the throttle is closed and the pedal is not to the floor. what would cause this?
Old Aug 11, 2009 | 07:37 PM
TopGear_'s Avatar
Default Re: need help!! idle problem after manifold install
Bump for help!!! I switched the throttle bodies so all the sensors would be the originals but that still didn't work. the tps and iacv should be fine( i've read that the tps might need to be adjusted but I don't see how it got out of adjustment in the first place) all the hoses seem to be fine. Nothing is leaking either. all bolts and nuts connecting the manifold are tight( and new gasket). there's some kind of electrical plug that is hanging under the manifold that is coming from a wiring harness but I cannot figure out what it goes to. I'm pretty sure it plugs into the block or head right under the manifold. but I'm not sure. it's weird as soon as the motor turns over it just revs right up until I shut it back off
any help would be appreciated!!!
Old Aug 11, 2009 | 08:28 PM
jinjabred's Avatar
You have a vacuum leak somewhere. The way I find them is with an evap smoke machine. Plug throttle opening and insert smoke through a vacuum port. Most shops around should have one of these machines. To be sure it's not IAC doing it I usually just pull IAC and put fingers over ports while someone else cranks engine if it still idles up you know it's not the IAC. Hope this helps :-)
Old Aug 12, 2009 | 12:04 PM
TopGear_'s Avatar
sweet, thanks for the help. i'll look around for the smoke machine.
you don't think it could be the tps? that's what people keep telling me.
Old Aug 12, 2009 | 09:40 PM
TopGear_'s Avatar
well I fixed the leak. the idle is fine.
but now the car wants to over heat after a few minutes of driving. my fan isn't kicking on at all. I'm thinking that was the switch that is hanging underneath the mani.
Old Aug 13, 2009 | 12:44 PM
TopGear_'s Avatar
anyone? I cannot find where that sensor plug goes
Old Aug 13, 2009 | 12:52 PM
kaiba's Avatar
nm
Old Aug 13, 2009 | 01:45 PM
8zero8's Avatar
on startup it would rev to the redline? what is that like 8.2k? thats a little high for a vaccum leak..
Old Aug 14, 2009 | 10:49 AM
TopGear_'s Avatar
fixed. the rear mani bracket was keeping it from getting a good seal against the head. I just took the bolts out of the rear bracket and it seals fine now. running good.
thanks for the help
Old Aug 14, 2009 | 03:12 PM
8zero8's Avatar
it would hit the limiter tho?
Old Aug 15, 2009 | 01:06 PM
TopGear_'s Avatar
no, i would shut it off before it got near the redline.
it's running great now, but now it's losing antifreeze somehow. Ive filled the over flow tank 3 times now and it still is running out.
Old Aug 17, 2009 | 07:38 PM
8zero8's Avatar
i think u really should consult with someone who knows exactly what theyre doing. not trying to belittle u in any way, but id rather tell u than ur motor take a **** on u.
Old Aug 18, 2009 | 11:15 AM
TopGear_'s Avatar
I had air in the system. I burped the radiator and it's back to normal. thanks for the help!
ek9_klone
Apr 29, 2015 07:57 AM
matto2413
Jun 1, 2005 11:36 PM
gtowni3
Aug 24, 2004 05:24 AM
miataguy
Aug 1, 2004 11:32 AM
Liquidx02
Mar 9, 2002 07:29 AM
