What will cause the radiator fuild to disappear
Old Aug 20, 2009 | 09:11 PM
asocallocal's Avatar
Default What will cause the radiator fuild to disappear
recently did a timing belt and water pump change. I dont know what cause this but when i was on the road driving, my temp guage went up and when i parked it, the fuild was gone.
What are some causes that would make radiator fuild to disappear?
Old Aug 20, 2009 | 09:55 PM
90blackcrx's Avatar
Default Re: What will cause the radiator fuild to disappear
Either you are burning coolant, or you are leaking it some where. Did the water pump seal ?
Old Aug 20, 2009 | 09:56 PM
loosh's Avatar
blown head gasket.. blowin smoke?
Old Aug 21, 2009 | 03:02 AM
jloehlein's Avatar
How much coolant did you lose and how far did you drive before you noticed it being gone. If you lost a bunch of coolant in a short period of time and didn't notice any smoke, a leak is more probable than a blown head gasket. Fill the car back up and run it in the garage, check for leaks.
Old Aug 21, 2009 | 01:09 PM
8zero8's Avatar
air bubbles in the system
Old Aug 23, 2009 | 05:11 PM
how do u burn coolant? im not blowin smoke. did the water n timing change like 6 months ago. What i did notice was when i pulled the car over when it was overheating was that is was making a constant whistling sound, like air is being forced out or something like that. after like 20mins, it stopped that sound. i was missing alot of coolant, maybe like 2 litters.
how can u lose coolant? bad gasket, leaks, and ?????
i dont think its a leak, can it be anything internal like bad rings or something?
Old Aug 23, 2009 | 06:12 PM
mouab18c1's Avatar
check your oil cap, see if it has any white milky **** under it
Old Aug 23, 2009 | 07:58 PM
drag_killer's Avatar
Try look at water pump area, maybe a bit leak
Old Aug 24, 2009 | 06:19 PM
8zero8's Avatar
check where you park your car for puddles on the ground
giantdny
Nov 6, 2006 07:13 AM
som3on3_10
May 18, 2006 06:56 AM
Osek206
Jul 3, 2005 10:14 PM
enwycee
May 10, 2005 11:13 AM
iam7head
Nov 21, 2002 12:38 AM
