pro2 cams
Old Aug 16, 2009 | 10:24 AM
torqueaholic's Avatar
New User
Default pro2 cams
greetings evry one im from the carribean and this is my first post here i wud jus like to say nuff repec to all d tuners and builders out there and honda all the wayy..
im running a b18c jdm stock..recently bought pro series intake manifold, type r header and a pair of skunk2 pro2 cams, springs and retainers.. my questions are.
can i run the cams wid stock cam gears,
b4 i get the piggy bak would the car idle decent enough if i just use bigger injectors..any help would b appriciated thanks....
Old Aug 18, 2009 | 01:44 PM
skunk2chris's Avatar
Default Re: pro2 cams
Not only can you NOT use Pro 2 cams with stock cam gears, but you cannot run Pro 2 cams on a stock bottom end. You need more compression to support those cams.
These cams need to be degree'd in properly using a degree wheel, and in order to degree a cam in properly, you need adjustable cam gears to make the proper adjustments and get the correct centerlines.
You will also need to have the motor tuned with these cams. I have listed a link below regarding cam degreeing and such to hopefully help you out.
http://www.skunk2.com/camshaft_tech.php
Old Aug 20, 2009 | 06:48 PM
New User
cool thanks man i appriciate it...
risktypeS
36
Mar 23, 2013 11:01 AM
da_all_day
May 29, 2011 09:45 AM
dirtyharryhatch
Oct 14, 2008 04:40 PM
TurboJdmEF9
May 26, 2006 02:16 PM
