not sure what happend?
Old Aug 24, 2009 | 09:33 PM
jordanz's Avatar
Default not sure what happend?
on my way to work I was coming down the off ramp from the freeway and my car backfired out the exhaust very hard. After leaving work the car is idleing around 600rpm and is kind of spitting and sputtering. whats really weird is if i 1/4 throttle through lets say 2nd gear, its drives okay until about 4k and loses power and spits and pops but if i get on it, it runs ok? if i rev the car it brakes up real bad after 3k rpm or so...im comfused what happened? 1997 civic lx, d16z6 swap still obd2 running a p2e ecu...? any suggestion are greatly appreciated!!!
Old Aug 25, 2009 | 05:52 AM
fcm's Avatar
fcm
Old Fart
Default Re: not sure what happend?
First thing I would check is timing.
Have you washed the engine bay/engine recently? 94
Old Aug 25, 2009 | 06:52 AM
jordanz's Avatar
no i haven't washed the engine bay...maybe timing did jump? it happened very suddenly...
Old Aug 25, 2009 | 06:54 AM
speedooo's Avatar
any cel's? sounds like a bad map sensor
what is it with people claiming maybe timing jumped? has anybody on here ever tried driving a sohc with the tbelt off 1 tooth? it doesnt run.
Old Aug 25, 2009 | 06:34 PM
street_ride14's Avatar
Your fuel is not burning in the combustion chamber like it should, and then it exits into your hot exhaust and internally explodes causing backfires. You are getting weak or no spark at times. Check spark plugs and wires, then check distrubutor.
Turbo_kid18
Sep 19, 2018 03:17 PM
turbotime
29
Dec 10, 2006 10:18 PM
civicex_88005
16
Jul 8, 2005 06:02 PM
turbotegrar
May 20, 2004 04:13 AM
Vp Special K
Mar 30, 2003 09:56 AM
