Question on LS/VTEC?
Old Jun 24, 2001 | 05:28 PM
MXPX's Avatar
New User
Default Question on LS/VTEC?
If i use the b18c1 head and have ITR cams and portflow retainers and ITR valve springs...will it be just as good as a B18c5 or better?
Old Jun 25, 2001 | 12:08 AM
boomslang's Avatar
Default Re: Question on LS/VTEC? (Rs-VTEC)
No, the B18c5 head would still be better.
Old Jun 30, 2001 | 05:57 AM
CRX_VTEC's Avatar
Default Re: Question on LS/VTEC? (Inlinefour)
the B18C head will give you higher compression. Type R head is almost exact to the B16 heads flow characteristics with the added slight port and polish. if your gunna go LS/VTEC..... use the B18C head. And as for the springs and retainers... they'll allow you to rev as high as the Type R but thats about the onlything they'll have in common.
Old Jul 2, 2001 | 07:01 AM
jg's Avatar
jg
Default Re: Question on LS/VTEC? (CRX_VTEC)
crx_vtec is right. If left stock, the b18c1 head will yield higher #'s. B18c5/b16a have a round combustion chamber as opposed to the rectangular shaped chamber of the gsr(b18c1) and will have a lower compression ratio due to the added area in the chamber. I believe the round chambers are better for a more efficient burn. If doing some serious modding, this should be thought of.
skylinerb26dett
May 6, 2010 06:35 AM
REKOX13
15
Sep 14, 2006 08:28 PM
87shytwhip
Apr 19, 2006 09:57 PM
DSR!
Oct 22, 2004 07:43 AM
turbopanda
May 12, 2002 10:38 PM
