Will this NA setup get a b16a2 into low 14's???
Old Jun 16, 2001 | 01:18 PM
HXMan's Avatar
Default Will this NA setup get a b16a2 into low 14's???
I want to get my b16a2 powered Hx into the low 14's...with such little displacement will this setup be good enough? I hope so, cuz it will cost lots of money, probably around $6000 I figure.
Toda Spec B's...or should I go with crower?
Toda Valve Springs
Endyn Rollerwave Pistons...overbore .25mm 12:1 Comp too high?
Aries Rods? Which rods should I use?
J-Spec ITR header? Good enough?
ITR TB
Good Cam gears and tuning.
270 cc/min Injectors? Too small?
P&P Head
OBD 1 P28 reprogrammed ECU from Hondata?
Dyno Tuning
I still want good midrange pull....I dont want to rev to 8500 all the time, and I would like to run on 93 octane which I can get here. I heard the Toda Spec B's have good midrange and great topend.
Old Jun 16, 2001 | 02:03 PM
GSpeedR's Avatar
Default Re: Will this NA setup get a b16a2 into low 14's??? (HXMan)
You should be close to 200whp with proper tuning and patience. I think that you could do high 13s on street tires since all this is in a Civic.
Should be quick...
Old Jun 16, 2001 | 04:53 PM
H22CIVIC's Avatar
New User
TODA SPEC B'S for sure.
Old Jun 16, 2001 | 07:06 PM
HXMan's Avatar
Default Re: Will this NA setup get a b16a2 into low 14's??? (GSpeedR)
Should be quick...
This sure would be nice....as there are some Honda's, DSM's, and other cars in my area I need to beat....plus...I just want to go fast.
Old Jun 17, 2001 | 01:28 PM
TheShad0w's Avatar
damn man just do an ls or crv conversion and you can run high 13s on slicks, low 14s w/ the right fuel system save yourself the other 4gs for something else yickes...
Old Jun 17, 2001 | 05:19 PM
pagong's Avatar
with all those mods youre doing, might as well step up to toda spec C's!
Old Jun 17, 2001 | 06:58 PM
FIVE.ONE.ZERO's Avatar
New User
Default Re: Will this NA setup get a b16a2 into low 14's??? (pagong)
you should be close to low 13s. i know a few b16s with bolt ons,ctr cams, and upgraded ecu hitting mid 13s on street tire.
lukeb89ef
17
Aug 25, 2011 10:37 PM
daNk9
Feb 19, 2004 03:48 PM
GQ 05YellowEVO8
Sep 4, 2002 03:15 PM
00 Si
10
Aug 20, 2001 06:13 PM
blackR#663
Jul 16, 2001 06:08 PM
