It's Summer Time! A/C help Needed!
Guys,
I have a 95 GSR and my ac doesnt work. It blows luke warm air. SO I go out and I see a kit for 134a and a pressure test comes with it for 25 bucks. I follow the instructions and I take a pressure reading of 45psi. The kit says this is way too high. Can anyone help? Any ac people in here? Yes the compressor is engaging and everything else seems fine. Any ideas would be a great help. Thanks
if your condensor is blocked by a bag or something like that it will cause the A/C not to work properly. the pressures inside the A/C system are determined by ambient temperature, did you use P/T chart when determining the correct pressure
[Modified by TurboType-R, 6:17 AM 6/17/2001]
