GSR tranny parts on B16 tranny?
I need to replace the clutch housing and differential in a B16 tranny from a '96 del Sol VTEC, will a GSR clutch housing and differential work with the remaining B16 tranny parts?
thanks,
Jared
thanks,
Jared
Re: GSR tranny parts on B16 tranny? (Jared)
differential won't work, not enough space ....by clutch housing, you mean pressure plate, if so then its a yes
Re: GSR tranny parts on B16 tranny? (eg6ajk)
No, by clutch housing, I mean that side of the tranny casing, also called bell housing in a rwd configuration.
thanks,
Jared
thanks,
Jared
the bell housing and top pieces are all interchangeable, the difference is the bolt pattern on the differential and the shape fo the carrier bearings. Also, you need to ad shims to put a GSR/type diff into a b16a/LS(92+) diff. Obviously you check preloads after doing this interchangeably.
Greg
Greg
mingbling
03-06-2004 05:03 AM
b16, casing, clutch, diff, differential, gsr, housing, interchangable, interchangeable, internals, parts, syncros, tranny, transmission, trany, works
