Short shifter problems
Old Jun 15, 2001 | 07:27 PM
W0oT's Avatar
Banned
Default Short shifter problems
well i just bought a 91 civic si hatch. the car came w. a shortshifter (brand?) ACT clutch, DC sports headers, random tech cat, and thermal exhaust. well it was fine for a while shifting but the weather has gotten to be around 97 deg. here in NY. well ever since the weather has gotten hotter i have noticed that it is really hard to shift my car into gear at a stop. any gear! i have to push so hard sometime i have to use 2 hands and i'm afraid the shifter will break. i'm not a small guy, but i noticed that every great once in a while it will grind 1st gear then shift fine. could a lack of transmission fluid be the cause or do i need to adjust my clutch pedal? i haven't checked the fluid yet but i'm going to tomarrow.
Old Jun 15, 2001 | 07:32 PM
Dr_pooface's Avatar
New User
Default Re: Short shifter problems (Nismo240sx1)
last owner probably killed the syncros
Old Jun 16, 2001 | 10:07 AM
91civicguy's Avatar
New User
I had the same problem with a 91 civic with zc motor, act clutch, si trans and such. I needed to adjust the clutch that was all. Use a clymer manual or whatever to find where the clutch adjustment is and adjusted to make it tighter.
Old Jun 18, 2001 | 05:03 AM
deviant94ex's Avatar
New User
Default Re: Short shifter problems (91civicguy)
i've been having the same problems with my dc short shifter installed in my 94 ex coupe. i also had a new clutch put in the same week so i wasnt sure what was causing the problem. just like was said before, it is really hard to get it in any gear from a stop in neutral. unless you are on a hill where the car can roll forward a bit and then it will slip into gear no problem. anyone else have any input on this topic. if it is the clutch needing adjustment i am going to take it back to the shop that did it and have them re-adjust it, for free of course! thanks for any hlep uyou guyd can give us.
CHRIS
Old Jun 19, 2001 | 05:03 AM
New User
Default Re: Short shifter problems (deviant94ex)
mugen727
Sep 30, 2009 09:16 AM
taimysho0
Sep 24, 2007 05:15 PM
ohiohonda
Feb 21, 2006 11:11 AM
dohcdelsol
Jan 7, 2005 10:11 PM
