Re-locating batter to the trunk
Old May 27, 2001 | 02:50 AM
Lyonel's Avatar
Default Re-locating battery to the trunk
I plan to re-route the battery to the boot to free up some space in the engine bay. How hard is this task? and what sort of cables should i be purchasing?
TIA
[Modified by Lyonel, 8:14 AM 6/19/2001]
Old May 27, 2001 | 04:40 AM
The ANTI-RICE's Avatar
New User
Default Re: Re-locating batter to the trunk (Lyonel)
I relocated mine in my 3rd Gen Teg. Its not really that hard, just very time consuming making sure all connections are away from high "wear" areas and snaking some of that cable through.
I used a battery box from WAL MART(13$), then i bought some generic battery cables(40$), then i purchased a high amperage circuit breaker with 150amp fuse(20$), then lastly i got a distribution block to connect all the POSITIVE wire under the hood into one block(30$)
Everything went smoothly, but make sure you ground your battery to somewhere on the BACK(where the tail-lights are)of the car. Mine didnt seem to work when i grounded it on the rear shock tower bolt. Dont know why, but mine just didnt?
Only drawback i have from the install is, i wish i could've used LARGER GAUGE power cable. The 4guage i used seems to loose power because the car's lights are dim at idle, then when i rev up, you can see the lights get just a shade brighter. Its nothing i loose sleep over, but if i were to do it again, id use 2gauge that time.
O yea, the battery strap that came with box, i tossed. Get one of those RATCHETING types. That way you can strap the lid down tight. The factory HONDA battery is very small when put inside this box. You may, as i, hafta use some rubber/foam pieces to hold it more securely. Ive got some pictures of my battery box in the trunk if you want. Its nothing special, jus looks like a box in the trunk on the passengers side.
Good luck,
Tony
Old May 27, 2001 | 09:22 AM
clockworks's Avatar
I just got the kit from Summit. It's pretty cheap and has good cable, 2 gauge I think, along with everything but a box.
Greg
Old May 27, 2001 | 07:50 PM
Gasoline Fumes's Avatar
Default Re: Re-locating battery to the trunk
I moved the battery to the spare tire well of my Wagon. I used the stock bracket to hold the battery down, and 2 gauge wire that I got for free. The total cost was $2 for the terminals.
Old May 27, 2001 | 09:04 PM
Stinkalope's Avatar
New User
I just ordered the kit from summit too... and a optima from ebay
Old May 28, 2001 | 01:56 AM
Lyonel's Avatar
Default Re: Re-locating batter to the trunk (The ANTI-RICE)
Thanks for the info guys. Tony, some pics would be great.
Old May 28, 2001 | 09:28 AM
broke's Avatar
New User
just for thought i would strongly suggest not moving it to the trunk unless you absolutely have to, you want the most possible weight in the front (without adding weight) that you can.
Old May 28, 2001 | 12:25 PM
Honda318dx's Avatar
Default Re: Re-locating batter to the trunk (broke)
Only if you are drag racing..
Old Jun 18, 2001 | 11:15 PM
Lyonel's Avatar
Default Re: Re-locating batter to the trunk (Honda318dx)
What's the diameter of 2-gauge battery cable? Is thicker always better?
TIA
trrbl1bmx
20
Jul 13, 2005 07:47 AM
nevin
Aug 9, 2003 03:53 PM
rasta420
Audio / Security / Video
Aug 7, 2002 10:48 PM
rasta420
Jul 31, 2002 08:48 PM
91sifreak
Apr 18, 2001 07:36 AM
