dying battery
Old Jun 13, 2001 | 05:44 AM
BK101's Avatar
Default dying battery
Need help ?
Something keeps draining my battery about once a week.
Usually happens over night period.
What to check first?
Can my remote starter alarm do this ? or a bad ecu ?
The lights and fan are the things i checked already.
Old Jun 13, 2001 | 06:17 AM
randomwalk101's Avatar
Default Re: dying battery (BK101)
bad battery?
Old Jun 13, 2001 | 06:27 AM
BK101's Avatar
Default Re: dying battery (randomwalk101)
I forgot to mention this is the second battery i have replaced.
Old Jun 13, 2001 | 07:00 AM
1) may be your alternator is not charging too well thus the battery is never full to begin with
2) Again, the battery. Try a different brand. DieHard is very good in my opinion.
Old Jun 13, 2001 | 07:50 AM
BK101's Avatar
If the alternator is bad. I am thinking i would get dimming problems and
power loss stuff. I can change the battery again with another brand.
Any other suggestions to check ?
Thanks
Old Jun 13, 2001 | 08:01 AM
BK101's Avatar
Can't i check the alt. by testing voltage with the car on and with the car off.
The Voltage sure be : 13.5 + with the car running.
Old Jun 13, 2001 | 12:49 PM
LostGsr's Avatar
It looks like you have a short somewhere. If the alarm is not installed properly its possible the short is occurring there. If this is the second battery you have replaced in a very short time then I doubt replacing it with a new battery will solve anything.
[Modified by LostGsr, 1:50 PM 6/13/2001]
Old Jun 15, 2001 | 10:33 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: dying battery (LostGsr)
Bad alternator. The diode pack is bad in it.
OR, check this first.
Check the OHMS between the CYLINDER head and the (-) TERMINAL of the battery. If it's more than 0.1 OHMS, you have a bad engine ground.
Outtie.
Old Jun 15, 2001 | 11:37 AM
BK101's Avatar
The reading from the alternator are:
13.7 with no load.
12.7 with fans on and headlights, AC and radio
0.3 amps current draw with car off.
Is this average?
smokecdxx
12
Jan 14, 2007 12:06 AM
b18cEK
10
Nov 6, 2006 02:27 PM
Tyler_Durden
Jun 19, 2003 09:55 AM
bluegoo
Nov 17, 2002 09:39 PM
97VTi
Jan 31, 2002 08:46 PM
