Can you check for bent valves by doing a Compression test?
Old Jun 14, 2001 | 12:53 PM
LostGsr's Avatar
Default Can you check for bent valves by doing a Compression test?
Will a compresson test tell you if you bend your valves? Thanks
Old Jun 14, 2001 | 04:08 PM
Sonic's Avatar
Default Re: Can you check for bent valves by doing a Compression test? (LostGsr)
Yes, if you bent a valve it's not sealing properly and you will lose compression from the poor seal...
Old Jun 14, 2001 | 04:34 PM
Ricehornet's Avatar
yup, if yer compression is low, you can have a bent valve....among other things i'd assume...but if you have a bent valve you WILL have low compression...
Old Jun 14, 2001 | 05:19 PM
LostGsr's Avatar
Default Re: Can you check for bent valves by doing a Compression test? (Ricehornet)
Cool thanks I feel much better now
Old Jun 15, 2001 | 04:33 AM
Cyber ITR's Avatar
what is the normal compression for b18c1 engine ?
i wanna do compression test with b18c1
thanks for any help
Old Jun 15, 2001 | 12:16 PM
Ricehornet's Avatar
Default Re: Can you check for bent valves by doing a Compression test? (VTEC_SiR)
shouldnt the compression be around 200psi or so on all 4 cylinders
Old Jun 15, 2001 | 12:29 PM
Sonic's Avatar
The number seems to vary, but should be at least higher 100's. The key thing when you do a compression test is that there is no variance between the cylenders. Less than 5% variance and you are golden.
H22AFerio
Oct 9, 2011 11:23 AM
The Dirty EJ1
Jun 30, 2008 12:37 AM
self_made
Jun 19, 2005 12:36 PM
SwiftTypeR
May 10, 2005 05:22 PM
RGoose18
May 21, 2004 10:13 AM
