rotten eggs
Old Jun 22, 2001 | 05:27 PM
blkbeast's Avatar
New User
Default rotten eggs
Whenever i'm driving faster than normal( shifting at around 5,000 rpm) and i have the temperature setting to hot with the fan off, i start smelling rotten eggs! I pretty sure that it's not me, so what could it be? When i put the setting to cold, everything is fine. I'm confused, can anyone help?
BTW it's a 94 ls with 65,000 miles.
Old Jun 22, 2001 | 10:42 PM
slickboy's Avatar
New User
Default Re: rotten eggs (blkbeast)
it's probably your clutch you smell, especially if you rev hard while changing gears. after a good round of hard driving, i can smeel a similar smell in my teg.
Old Jun 23, 2001 | 12:41 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: rotten eggs (slickboy)
catalitic convertor is wasted.
Old Jun 23, 2001 | 12:49 AM
TurboType-R's Avatar
New User
Default Re: rotten eggs (Aj.)
the rotten egg smell doesn't mean your cat is bad, it means your cat is working, it is converting the sulfur passing through it
Old Jun 23, 2001 | 12:56 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: rotten eggs (TurboType-R)
It's supposed to BURN the excess contaminants. That's what a CAT is. If working properly, it's like a mini-oven. Since he can smell it, it's not doing its job.
Old Jun 23, 2001 | 01:48 AM
New User
cats are used to create a chemical reaction (caused by heat) to change HC, CO and Nox into none harmful gases such as H20 (water), CO2. a 3 way cat is made up of paladium, platnium (spelling), and rhodium. a cat does work off of heat, but that is only because it takes at least 600-800 degrees F before the metals in the cat begin to cause a chemical reaction. the more sulfur, that passes through the cat the more you smell the rotten egg smell. that is why he can smell the rotten egg smell. he most likely got a tank gas with a lot of sulfur, or he is burning oil, which contains sulfur it could also be the clutch. if he goes to any shop and has it looked at they will tell him this is normal.
[Modified by TurboType-R, 10:49 AM 6/23/2001]
[Modified by TurboType-R, 10:52 AM 6/23/2001]
Old Jun 23, 2001 | 08:18 PM
blkbeast's Avatar
New User
Thanks for the replies. TurboType-R, that was very informative. My bro told that my cat is clogged and i didn't believe him. Hopefully everything is okay.
Old Jun 24, 2001 | 10:01 PM
quikrpm'z's Avatar
Default Re: rotten eggs (owkone)
its probably the cat. I agree with AJ.
Old Jun 25, 2001 | 10:18 AM
New User
Default Re: rotten eggs (quikrpm1)
so if the cat is clogged, wouldn't you have a decrease in performance, because of the lack of exhaust being able to flow. wouldn't you smell less exhaust gases? if the cat was wasted and the exhaust was still able to flow through wouldn't there be no chemical reaction taking place in the cat. the exhaust gas would smell like you had no cat at all. how can either situation cause a rotten egg smell?
Old Jun 25, 2001 | 12:11 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:11 AM 11/16/2006
kupras
Oct 18, 2004 02:39 PM
hYpE-R-29
Aug 21, 2003 09:07 AM
onyx00
Jul 21, 2002 06:38 PM
Maengelito
Apr 10, 2002 06:41 PM
JoshRambo
Oct 1, 2001 02:31 PM
