Engine problems, please read!!
Old Jun 20, 2001 | 04:05 PM
boomslang's Avatar
Default Engine problems, please read!!
Okay here is the problem. My prelude died when I was just cruising last night. I wasn't boosing. The car lost power and sputtered to a stop.
The car starts up and idles just great. But it will only rev to about 3K and then fall back down to idle speed. When put into gear the motor doesn't have enough power to move the car and the rpms drop to nothing.
The plugs, rotor, distibutor cap and fuel filter have less than 10k miles on them. I checked them out throughly this morning and all look okay. Plugs look normal. I tried a new set of plug wires and it didn't help.
**The car drove okay this moring when the motor was cold, then the problem came back. ** I asked a mechanic at a honda dealer and they didn't know. I disabled all extra elctronics to help find the problem but nothing helped.
I don't have a CEL coming on at all. Please help!!
Old Jun 20, 2001 | 05:16 PM
VTECAcuraGSR's Avatar
Default Re: Engine problems, please read!! (Inlinefour)
You might want to check the coil or the ignitor. Usually, if one of these things are faulty they will work ok when cold but when they heat up they fail. Hope that helps
Old Jun 21, 2001 | 08:43 PM
rioninja's Avatar
Are you sure its getting enough fuel? You might have a faulty fuel pump or a kinked line.
Old Jun 21, 2001 | 09:47 PM
Phuc yiu's Avatar
New User
Default Re: Engine problems, please read!! (RioNinja)
how would you check if there was a kinked line or if the fuel pump was messed up?
Old Jun 23, 2001 | 09:43 AM
tony300's Avatar
New User
Default Re: Engine problems, please read!! (Phuc yiu)
Check your fuel system starting from fuel filter to fuel injector. If the revs change is sudden during cruising, it might be the injectors, dump 1-2 bottles of fuel injector cleaner to your fuel and see how it goes.
Old Jun 24, 2001 | 03:27 AM
mike2016's Avatar
New User
did you check your MAP and TPS sensor?
superdat1
May 1, 2008 10:20 PM
NightHawk
16
Apr 16, 2003 05:52 PM
Speedz
Sep 10, 2002 06:06 PM
boomslang
Jun 23, 2001 10:21 AM
boomslang
Jun 22, 2001 10:37 AM
