engine will not crank or anything
Old Jul 27, 2002 | 10:16 AM
chipper's Avatar
Default engine will not crank or anything
i just finished up swapping a JDM b20b into my 90 integra LS and i started the car yesterday and turned on my headlights, engine shut off and does nothing now. i dont have any idea where the wiring could be messed up b/c i kept all the wiring in tact during the swap. after this happened i removed all the wires that someone had under the dash for a security system, there were a ton of barely connected wires and even some that were just not connected at all. all the wiring is back to the original under there now. i dont see anything under the engine bay that could be wrong, and i dont see any fuses blown........WHAT THE HELL!!!!!!?!?!?!?!?!
heres some more of what has been going on with the electrical system
http://www.g2ic.com/forums/showthrea...threadid=28792
i just bypassed the ignition system to test the starter and it works.......so there must be a short in the ignition system somewhere
what should i look for first??? im completely in the dark with this one
where is the starter relay??? it says its right near the head unit, but i cant find it
[Modified by chipper, 7:23 PM 7/27/2002]
Old Jul 27, 2002 | 05:38 PM
chipper's Avatar
Default Re: engine will not crank or anything (chipper)
help me!!!!
Old Jul 27, 2002 | 08:26 PM
minime's Avatar
try checking the 80 amp fuse under the hood fusebox.
Old Jul 28, 2002 | 09:18 AM
Malgerus's Avatar
Check for loose grounds, also check wires for high resistance, if you want to.
Listerofsmeg
Sep 4, 2016 01:56 PM
anothersickhatch
45
Jun 2, 2016 10:51 AM
NAlover
16
Jul 28, 2006 10:59 PM
chipper
Jul 28, 2002 02:17 PM
