V-AFC wiring problem
Old Jul 30, 2002 | 02:21 AM
blackANESE's Avatar
Default V-AFC wiring problem
I have a JDM SiR II B16 in my 93 dx hatch.
I have everything wired up for the v-afc correctly(been over many times).
Except The "VTM" wire (whatever the hell that is)......According
to the Apexi wiring diagram the VTM wire is where the Vtec oil pressure
switch is. I have the Oil pressure wire (D6) wired correctly b/c it ran fine
with no CEL's before the v-afc install. THe apexi manual shows the vtec
oil pressure at D17.
Now, I spliced the VTM wire into the oil pressure wire and left one end of the
oil pressure wire un-connected. Should I just solder the VTM wire directly into
the oil pressure wire?
It bogs like crazy when vtec hits, and hardly wants to pull to redline with no check engine light. Now here's the funny part. When it throws a cel, it pulls hard again and feels fine (but has the check engine light)......WTF!!!!
How should I wire the VTM wire and oil pressure switch????? Somebody here
must know. Please help.
I know it's confusing but try to follow, please.
Old Jul 30, 2002 | 06:34 AM
AutoXsi2000's Avatar
Default Re: V-AFC wiring problem (blackANESE)
I would also like to know, just bought one yesterday also. this is for a 00 si.
Old Jul 30, 2002 | 10:32 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
if it's JDM, then it probably doesn't have a VTM. just leave that wire out and see how it runs.
for the 00 si, the diagrams should fit anyway, and yes they will have a VTM.
Old Jul 30, 2002 | 10:40 AM
blackANESE's Avatar
Default Re: V-AFC wiring problem (dLo GSR)
It's a JDM motor, but I have the USDM harness. I tried leaving the VTM disconnected before but all that did was throw codes.
Old Jul 30, 2002 | 10:48 AM
which diagram are you using?
Old Jul 30, 2002 | 10:52 AM
kinesistech's Avatar
If the ecu is US, chances are it uses it. The VTM wire has to be wired into the ecu side not the sensor side. The sensor could give a ****. The ecu is concerned with the wire. Disconnect the vtm (car side) wire from the ecu and put the vtm (vafc) wire in its place, to the ecu.
Old Jul 30, 2002 | 01:14 PM
blackANESE's Avatar
Default Re: V-AFC wiring problem (kinesistech)
If the ecu is US, chances are it uses it. .
Ya the ECU is a chipped P28. Thanks for the info kinesistech. I'll prob. IM u if with more ?'s.
Bimmerman
Jun 15, 2005 05:23 PM
LAKER HATER
May 16, 2004 11:52 AM
1insaneR
May 10, 2004 10:19 PM
racinskittle
Sep 27, 2003 09:44 PM
blackANESE
Jul 30, 2002 01:13 PM
