Idle Problem & Code 43
Old Jul 25, 2002 | 10:18 PM
Litoman's Avatar
Default Idle Problem & Code 43
I have a 92 Civic DX HB. And changed my engin, to a 99 Civic CX. Not a big deal, but I am having problems with my idle. The car is rough idleing, at any temp. The rpm's are normal for a few min. then drop to almost 0. When I drive the car, it seems to run normal. But if I try to keep a steady speed the check engine light comes on. (code 43) I have checked my injectors,distributor,plugs,wires,and changed my fuel filter. I also checked my oxygen sensor. The problem is still the same. What could it be?
[Modified by Litoman, 10:33 AM 7/22/2002]
Old Jul 25, 2002 | 10:37 PM
Chiovnidca's Avatar
Default Re: Idle Problem & Code 43 (Litoman)
What's your fuel presure?
Old Jul 26, 2002 | 06:45 AM
88_SC_CRX_Si's Avatar
New User
Have a real close look at your cam/crankshaft alignment...
Old Jul 26, 2002 | 11:41 PM
bullz's Avatar
Default Re: Idle Problem & Code 43 (88_SC_CRX_Si)
Check your Fuel Press, FPR, and check for vacuum leaks.
Old Jul 30, 2002 | 02:59 PM
Litoman's Avatar
The fuel pressure seems to be normal. The fuel pressure starts to go up when the car starts to idle rough.
Old Jul 30, 2002 | 03:13 PM
dohcsideSi's Avatar
i'm not sure why but i've seen a bunch of code 16 and 43's in the past couple of weeks...weird, i had a code 43 on my ls/vtec myself until a got a chipped p28....poof gone
Old Aug 1, 2002 | 07:20 AM
Litoman's Avatar
Default Re: Idle Problem & Code 43 (Chiovnidca)
xlusiveracer
Honda CR-V & Element
Jan 6, 2017 05:54 AM
hillbillycivic
29
Nov 10, 2012 04:40 AM
JdmEG6559
Nov 7, 2012 05:47 PM
ls-rex
22
Apr 26, 2009 07:52 AM
