Replaced secondary o2 still getting code 65
Old Jul 29, 2002 | 06:43 PM
Qwikrex's Avatar
Default Replaced secondary o2 still getting code 65
Ok I installed a new secondary o2 sensor and I'm still getting the same code 65 secondary o2 sensor code. Is there a fuse that might be blown tha is connected to the secondary o2? Also did I wire the new o2 in correctly? Green=signal ground, White2 signal. What are the other two wires?
Old Jul 29, 2002 | 06:53 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Replaced secondary o2 still getting code 65 ([VTEC]TL)
................Green=signal ground, White2 signal. What are the other two wires?
Heater wires.
Did you clear the ECU? It remembers stuff
Old Jul 29, 2002 | 06:57 PM
Qwikrex's Avatar
Default Re: Replaced secondary o2 still getting code 65 (B18C-EJ1)
yup, I'm clearing the ecu every time, it just keeps coming back. Everything seems wired correctly. My only guess would be a blown fuse somewhere, but what fuse is connected to the secondary o2?
Old Jul 29, 2002 | 07:31 PM
B18C-EJ1
Guest
Posts: n/a
There are no fuses between the O2 sensor and the ECU.
You fugged something up
98exturd
Aug 13, 2007 06:40 PM
kcrxxx
Aug 13, 2007 05:10 PM
Eucalyptus lude
Jun 3, 2005 01:42 PM
Qwikrex
Jul 29, 2002 08:23 PM
