jackin up a lowered car
my 2 ton jack can't fit under my integra because it's to low. anybody have any ideas on what to do...what i do now is take out my stock one use it then put the 2 ton under it once the car is lifted enough, but it's kind of a hassle. What do you guys do
i line up the jack with the front jack point, move it it as far as possible, then reach down and lift up the front of my car slightly while i use my foot to push in the jack into place. hey, it works for me
all yo uneed is a couple small pieces of wood, wider than the rim, you can keep them in the back. you may need 1 if the ires are good but if you have a flat on the road a couple will guarantee you can get a jack under it if need be.
[Modified by virginia_dude, 9:36 AM 7/26/2002]
Get the rhino low pro ramps. You car can drive right up that biznitch. I use it on my M3 as well and that is pretty damn low...
Walmart or Target: 30 bones...
i have heard the OEM jack works great even on lowered car
drive it up on two bricks in the front and the jack it up from the side. As far as the back goes, i jack it using the tow hooks or drive it up bricks also.
216.226.142.95:27016
Apr 7, 2003 04:48 AM
