weird problem....look here
Old Jul 26, 2002 | 06:12 PM
Mikey3000's Avatar
Default weird problem....look here
i just hooked up a resistor box to see if it would make my ecu fuse stop blowing. it seems as though it's working. but since then, when i go to turn my car off, the motor will stay on for about 3 seconds AFTER i turn the key to the off position! WTF? does anyone have any idea why it's doing this? it's not really a problem persay, it's just annoying. btw: i hooked the resistor box up like it says to on hondata's website.
Old Jul 26, 2002 | 08:11 PM
BreakStuff's Avatar
New User
Default Re: weird problem....look here (Salvatore Leone)
Do you know why your ECU is blowing fuses?? You ECU shares circuits and it may be something other than your ECU that is causing the problem...
Old Jul 26, 2002 | 11:35 PM
bullz's Avatar
Default Re: weird problem....look here (BreakStuff)
Yeah check to see if you have a short cicuit in the wiring. But if that is not the case then you might have idle speed too high.
Old Jul 27, 2002 | 04:36 AM
Mikey3000's Avatar
well it's not blowing the ecu fuse anymore. i mean it hasn't since i hooked up the resistor box (wed). my question is about the car not turning off when i turn the key off.
Zynemisis
Mar 12, 2017 01:44 PM
nkcalvert09
Jun 10, 2011 03:59 PM
Jason-
Aug 22, 2006 01:30 PM
CiViC SiR
May 18, 2004 03:26 AM
