High Idling problem !
Old Jul 27, 2002 | 11:07 PM
hybrider's Avatar
Default High Idling problem !
after being warmed up and at a complete stop of course, it will idle at 1,500 RPMS for a good 10+seconds, after that it will drop down to 900/1000, is this normal?
before once stopped it would drop to 800/900 which is normal, but the last few days it has been stuck that high all the time, till finally dropping down after an extended period of time
any ideas? thanks in advance
Old Jul 27, 2002 | 11:14 PM
gaskleppie's Avatar
Default Re: High Idling problem ! (hybrider93)
what ECU are you using?
Old Jul 28, 2002 | 11:55 AM
hybrider's Avatar
Default Re: High Idling problem ! (gaskleppie)
p72/stock
Old Jul 28, 2002 | 12:59 PM
gsr98vtec's Avatar
check the tps sensor at the throttle body with a volt meter. it may be off. also, check the iac screw in the TB as well you might need to adjust it or you might have a loose vaccum line in the fuel system somewhere causing a high idle. that happened to me, the line from the intake mani to the FPR came off raising my idle really high by about 500rpm
Old Jul 29, 2002 | 12:31 PM
gaskleppie's Avatar
Default Re: High Idling problem ! (gsr98vtec)
Maybe your Throttle valve isn’t closing enough.
Try to adjust it a bit closer.
With the eacv valve connector loose the RPM's should be 650.
If it’s higher, you got an air leak. Maybe a hose, maybe the throttle.
BTW. I've got a really big problem myself. My CRX ed9 with B20-Vtec is stolen!
In Holland it's not possible to sell it because everybody knows me. But maybe it’s shipped to Greece.
I assume that you've got a Honda site in Greece. Can you warn me if a B20 powered CRX is sold in your country?
Maybe put it on a Greek BBS?
You can see the car on my photosite: http://www.home.zonnet.nl/frank_typer/
Old Jul 29, 2002 | 01:00 PM
hybrider's Avatar
they actually steal cars in holland? see what not qualifying for the WC does? heh
im not in Greece currently, and what are the chances its cruising in the meditteranean all the way from holland? oh well, i`ll post it up on a couple of honda .gr sites
good luck
Old Jul 30, 2002 | 10:03 AM
gaskleppie's Avatar
I'm not a football fan.......
I'm trying everything to get my car back!
Its maybe the only B20-Vtec in europe, so its pretty hard to sell here.
I hope you can help me!
protopro88
Apr 8, 2011 03:41 PM
shadow29485
Feb 21, 2008 01:36 PM
vtec94civic
Aug 9, 2005 03:35 PM
caLiH22A
Aug 24, 2004 08:05 PM
Speedra500
Aug 3, 2004 07:13 AM
