trouble starting up now...
ok, i'm selling my zex cam, so i took it out today and put back in my stock cam. everything is set properly, cam gear and distributer both lined up correctly, everything tightened back to spec. when i start up the car, it starts up, but sounds like it sputtering, almost sounds like a domestic (glub glub glub). the thing sounds like its about to die and something definitely isn't right. i did a valve adjustment as well. could my timing belt or cam gear be off by like a tooth or something? what else could be causing this? i've installed/uninstalled cams before and had no trouble, but now this. please help. thanks
-alan
-alan
If thats the only things you messed with then it would have to be something with the timing belt. Did you adjust it properly? It could be off a tooth since its running like ****.
Thanks, J
Thanks, J
ah, fixed it. my cam gear and distributor were lined up correctly, but my crankshaft was not at tdc when i put the belt on. lined everything up, put the belt back on, and it runs fine. thanks for the help
-alan
-alan
Ef4doorwagon
13
May 17, 2014 06:09 PM
DMCCOY
12
Jan 9, 2009 08:39 PM
EK4 hatchback
May 31, 2004 08:45 PM
