h22a1 97 engine problems
Old Jul 25, 2008 | 12:38 PM
ashflash's Avatar
Default h22a1 97 engine problems
i have a 1993 eg civic hatch with a 1997 h22a1 in it
im having engine problems when i turn my car on there is loud knocking noises coming from the engine when i step on the gas the knocking noise gets faster anyone know what it could be or how to fix it
Old Jul 25, 2008 | 03:59 PM
racerxh00's Avatar
Default Re: h22a1 97 engine problems (ashflash)
you sir have a rod knock. time to rip the motor out and rebuild
Old Jul 25, 2008 | 04:51 PM
sprayinBseries's Avatar
Default Re: h22a1 97 engine problems (racerxh00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxh00 &raquo;</TD></TR><TR><TD CLASS="quote">you sir have a rod knock. time to rip the motor out and rebuild</TD></TR></TABLE>
x2
Old Jul 25, 2008 | 05:13 PM
woolydotmatrix's Avatar
Yeah I would have to agree on the knock being bad....I you caught it early enough you might be able to patch it with new bearings.......need to pull the pan and the rod caps and main caps to tell.......as long as th crank is not scored (at all) then bearings replacement will get you on your way(again I said patch, like a band-aid)
If you bearings are shot you might want to look elsewhere for damage also....
The crank gets oil first and the cams last so if your crank got starved for oil then your cams might have got hurt too......You can replace the bearings with the engine still in the car(messy and a pain in the @ss) but be vey careful with the order in which you take it apart and the torque specs that you use......If the crank journals or the cam journal are scratched enough to grab your fingernail on the its trashed and you nedd to start over with a fresh crank and go from there......keep us posted on your findings
Old Jul 25, 2008 | 06:38 PM
ashflash's Avatar
Default Re: h22a1 97 engine problems (woolydotmatrix)
what do you think total rebuild would cost cause a jdm h22a is 1800 lol
Old Jul 26, 2008 | 04:10 PM
E-Money's Avatar
Old Jul 27, 2008 | 10:58 AM
teg_95's Avatar
On my old ls i over reved and caused a knocking. it was really loud, and when i hit the gas it got faster, but before we broke down the motor we did a quick valve adjustment and it ran fine, no knock or anything. but i guess i cant really hear your knock.
teg gs
Sep 19, 2018 02:21 PM
JDM2k1Civic
Honda Civic (2001 - 2005)
Aug 30, 2009 04:33 PM
qazaq
Dec 30, 2008 06:57 PM
dacrxkid4rm253
Nov 29, 2007 12:07 PM
Naturally Aspirated
35
Oct 8, 2004 04:57 PM
