h22 tranny fluid???
Old Jul 21, 2008 | 04:17 PM
96integralsvtec's Avatar
Default h22 tranny fluid???
where do i pour in the fliud on my h22 tranny?where is the bolt i take out?let me know thanks
Old Jul 21, 2008 | 04:30 PM
woolydotmatrix's Avatar
Default Re: h22 tranny fluid??? (96integralsvtec)
One of two ways......above and more rearward from the drain bolt is the fill bolt.
remove the fill bolt and fill with Manual trans fluid (honda MTF) untill it runs back out of this hole (while on level ground......or remove the fill bolt and the speed sensor (top rear of trans w/three pin plug) then fill through the speedsonsor hole until fluid runs out of the fill hole (again on level ground or lift).....should take 2 to 2 1/2 quarts ...
bad 91 teg
Feb 1, 2011 04:09 PM
petergriffen
Jan 29, 2006 06:12 AM
xd69
Jul 16, 2005 05:44 PM
93preludeh22
Oct 17, 2004 11:44 PM
2lobes1engine
26
Jun 29, 2004 08:27 PM
