Best Transmission to Use, Del Sol EV Conversion
Old Jul 24, 2008 | 01:21 PM
pawolf's Avatar
Default Best Transmission to Use, Del Sol EV Conversion
Perhaps one of you Guru's know this off the top of your head. I wish to convert a 95 Del Sol to Electric. The Del Sol has front end damage and is stripped of all front suspension and drive train. It is an AT car. I will need to install a MT and would like to know which trans would be best in regards to being robust (strongest) easy to tune (change gears) etc. I would like to be able to just drop in using OEM mounting, linkage, axles as if going in behind a OE engine. I am new and do not yet understand the series b, d etc. designations so a reply of (95- 00 Civic 1.5L) would help. Also is there a manual steering rack that will bolt up. I am not sure about the gutting a power rack to make it a manual is the right way to go. Last question is the 93 Civic front suspension / clip the same or usable. I have a parts car. Thanks for you help.
Old Jul 24, 2008 | 05:25 PM
slowcivic2k's Avatar
Default Re: Best Transmission to Use, Del Sol EV Conversion (pawolf)
You won't need a tranny if you have a good AC motor, all you'll need is a differential and axles.
Old Jul 25, 2008 | 07:34 AM
pawolf's Avatar
Default Re: Best Transmission to Use, Del Sol EV Conversion (slowcivic2k)
While I know that all I need is a drive box. That would add $2000.00 to the conversion. Plus the extra machine work. A direct drive box also does not allow for the option of gear selection. My question was "Which Honda tranny will bolt in as factory and is the strongest"
dafiltafish
May 7, 2015 05:06 PM
delslow45
19
Sep 11, 2012 05:00 PM
JDW
Nov 28, 2009 07:56 AM
spanishstud
Aug 26, 2008 12:21 PM
