Idle Problem
Old Jul 23, 2008 | 10:37 AM
Makdaddynuge's Avatar
Default Idle Problem
I have a obd2 LS motor swap in a 95 civic cx. It has a idling problem, going up and down every so often. Its using a 2 wire IACV and an obd1 ls ecu. Is there something special that needs to be done when doing the OBD-2 motor to obd-1 car with this IACV? Or is the iacv just going out?
Old Jul 23, 2008 | 12:18 PM
vtecb18c's Avatar
Default Re: Idle Problem (Makdaddynuge)
i think its just on its way out...your TPS could also be the culprit
Old Jul 23, 2008 | 03:04 PM
fodofosho's Avatar
on the bottom of the throttle body there is a valve that helps control idle also. i fixed idle problems on many b series by adjusting that. just take the 2 screws and cover off the back and there will be a white plastic type of nut with a plunger in the middle. just screw that plastic nut down tight w/wide flat tip screwdriver,and you should be alright
Old Jul 23, 2008 | 03:06 PM
ok, so it has nothin to do with obd2 motor in an obd1 car? like some type of wiring i missed or swap item.
Old Jul 23, 2008 | 03:27 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Makdaddynuge)
did you use a "spill free funnel" to bleed the coolant after the swap? Air bubbles trapped in the cooling system can cause idle fluctuations
Old Jul 23, 2008 | 07:13 PM
yeah i keep meaning to bleed the coolant from any air.
Old Jul 24, 2008 | 10:14 AM
SinsEvil666's Avatar
clean the IACV and ur FITV using throttle/carb cleaner. Follow the link for specific instructions on cleaning the FITV
https://honda-tech.com/zerothread?id=1564019
Modified by SinsEvil666 at 1:54 PM 7/24/2008
Old Jul 24, 2008 | 11:55 AM
clean the what and my FITV?
looks like your missing a word, for the first thing i should clean
seanbev24
May 18, 2009 02:03 PM
rorik
Jun 4, 2008 10:19 AM
stivic
Jul 18, 2007 08:13 AM
