which one is it? 600 hp or 300 hp?
Old Jul 24, 2008 | 09:26 PM
turboorsupercharger's Avatar
Default which one is it? 600 hp or 300 hp?
Does a stock 97 prelude auto trans hold 300hp or 600hp? i have people telling me both
Old Jul 24, 2008 | 09:32 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: which one is it? 600 hp or 300 hp? (turboorsupercharger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboorsupercharger &raquo;</TD></TR><TR><TD CLASS="quote">Does a stock 97 prelude auto trans hold 300hp or 600hp? i have people telling me both </TD></TR></TABLE>
One of these numbers is extremely difficult for me to believe. Guess which one?
Old Jul 24, 2008 | 09:34 PM
Default Re: which one is it? 600 hp or 300 hp? (nsxtasy)
so do you think like 330 maybe 340 is pushing it?
Old Jul 25, 2008 | 05:20 AM
sprayinBseries's Avatar
automatic transmissions are a little more sensitive to horsepower upgrades than manual. id say if your actually going to try and make that much and put it through an auto trans. i wouldnt go to far over 300 and you torque converter might not like much more torque than the factory motor had. just be cautious with how much power your trying to put through the trans and listen to it. dont go crazy and blow it up.
Old Jul 25, 2008 | 08:07 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: which one is it? 600 hp or 300 hp? (sprayinBseries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sprayinBseries &raquo;</TD></TR><TR><TD CLASS="quote">automatic transmissions are a little more sensitive to horsepower upgrades than manual.</TD></TR></TABLE>
Yup. That's why Honda de-tuned the engine in the NSX so that it makes only 252 horsepower in the automatic transmission versions (which comprise about 9 percent of NSXs), vs 270-290 for the manual tranny cars - they were worried that the automatic couldn't reliably handle the higher horsepower.
And if the automatic in the NSX couldn't handle it, I wouldn't expect the one in the Prelude to do so.
Old Jul 25, 2008 | 12:10 PM
MR.johnson's Avatar
after 250-275 i have seen them slip/clunk.
time for a manual swap...
Old Jul 26, 2008 | 02:41 PM
slowcivic2k's Avatar
Default Re: which one is it? 600 hp or 300 hp? (MR.johnson)
Eliminate the accumulators (or stiffen them significantly), get some good frictions, and up the line pressure, there are some kits out there for this. Get a good external cooler too. They can hold more power than people think. The preludes have 4 frictions per gear, put 100-180psi behind that piston and that gear is not going anywhere, especially when the accumulators are eliminated/disabled.
What is the redline on the auto NSX vs manual, and is the torque the same? Given the displacement is the same torque should be too, RPM does not matter in this case. Torque is the true measure of an engines output, RPM is just a figure to tell you torque/rpm relationships IE "horsepower". Most auto's have a lower redline and thus less HP but similar torque.
https://honda-tech.com/zerothread?id=2086594
Modified by slowcivic2k at 5:51 PM 7/26/2008
turboorsupercharger
Jul 25, 2008 09:57 AM
chu77
Jun 12, 2006 07:03 AM
BoostFrenzy.com
Jan 3, 2006 10:24 PM
IntegraPrez
Jul 18, 2005 03:07 PM
ricoMugenlude97
Jan 28, 2005 09:21 PM
