changing a type r Lsd into a Ls tranny?? PLEASE HELP!!
Old Jul 19, 2008 | 08:50 PM
TurboB16A300Hpteg's Avatar
Default changing a type r Lsd into a Ls tranny?? PLEASE HELP!!
i have a type R tranny right now with helical LSD that i broke 3rd gear in it soo i bought a LS hydro tranny with a circitwerks Pro spool in it i was gunna take my LSD out of my type r n swap it into my LS is there any additional Work i need to do as far as Shimming any thing for fitment or changing Final drives or what not ?? thanks for the help HT!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 19, 2008 | 08:51 PM
Default Re: changing a type r Lsd into a Ls tranny?? PLEASE HELP!! (TurboB16A300Hpteg)
by the way the type r is hydro tranny also
Old Jul 20, 2008 | 05:36 AM
Any one????????
Old Jul 20, 2008 | 05:34 PM
Cimburke23's Avatar
its a bit of work to swap, have to change LSD w gear, countershaft gear and reshim the diff so its within spec
Old Jul 21, 2008 | 04:42 AM
Korch94's Avatar
Default Re: changing a type r Lsd into a Ls tranny?? PLEASE HELP!! (Cimburke23)
you could sell the itr lsd and buy a b16. the b16 will drop in given you remeasure the shims. the difference is that the b16 unit is viscous and not gear driven like the itr one.
and as stated, you could swap out your countershaft and ring gear for one from an gsr or itr and you can use the itr lsd given u remeasure the shims.
Old Jul 21, 2008 | 07:53 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: changing a type r Lsd into a Ls tranny?? PLEASE HELP!! (Korch94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Korch94 &raquo;</TD></TR><TR><TD CLASS="quote">
and as stated, you could swap out your countershaft and ring gear for one from an gsr or itr and you can use the itr lsd given u remeasure the shims. </TD></TR></TABLE>
no you couldn't. The LSD diffs use a larger ring gear.
Will work fine- you just need to replace the countershaft of the LS trans with the one from the ITR trans.
Replace diff and measure carrier bearing preload and adjust as necessary.
Old Jul 21, 2008 | 07:29 PM
Default Re: changing a type r Lsd into a Ls tranny?? PLEASE HELP!! (Evs-One)
haha Keeping the spool it looks like
Old Jul 22, 2008 | 05:00 AM
jody754's Avatar
wanna sell the lsd
xzodiackillerx
Transmission & Drivetrain
Feb 6, 2012 08:40 PM
SilverEk3dr
Jan 25, 2010 02:05 PM
bracket 4 life
Feb 13, 2005 10:05 AM
crexer
May 14, 2004 04:23 AM
Must be VTEC
Nov 23, 2003 10:43 PM
