Aftermarket CV AXLES?
Old Jul 20, 2008 | 05:47 PM
ganjasnack's Avatar
Default Aftermarket CV AXLES?
hey i plan on running around 400 to 450 whp on my integra, i am looking for cv axles that will be able to hand that with no problems. im trying not to spend a lot but i want quality axles that wont break.
Old Jul 20, 2008 | 08:37 PM
vtecb18c's Avatar
Default Re: Aftermarket CV AXLES? (ganjasnack)
im using gators race axles and i have no complaints...they also make street axles that are pretty heavy duty...a little pricey but worth it
Old Jul 21, 2008 | 10:08 AM
inspyral's Avatar
A lot of people run high HP on OEM or OEM replacement axles. The key is to preload the clutch on launch instead of just dropping it.
Old Jul 21, 2008 | 01:02 PM
ganjasnack's Avatar
Default Re: (inspyral)
whats preload the clutch?
Old Jul 21, 2008 | 01:47 PM
inspyral's Avatar
Search "clutch preload" and you should find several threads about this. It's basically holding the clutch right at the slipping point and setting your launch RPM with the throttle while using the hand brake to keep the car in place. When it's time to go, you release the clutch/press the throttle(or continue to do so if you have launch control built-in to your EMS)/and drop the hand brake all at once. This takes reduces the typical strain from the usual launch technique of just dropping the clutch at high RPM. Since you aren't dropping the clutch the drivetrain doesn't get shocked, which is usually when people break axles with higher HP/wheel hop.
edit - found this thread in about 5 seconds:
https://honda-tech.com/zerothread?id=1382054
ek9800
May 19, 2005 12:17 PM
torr
Sep 9, 2004 06:15 PM
IntegracinGSR
Jun 28, 2004 10:03 AM
91glassycrx
May 17, 2004 07:40 PM
egracer44
Aug 9, 2003 12:11 PM
