idle problem, '99 b16a2
Old Jul 18, 2008 | 03:31 AM
twisted civic's Avatar
Default idle problem, '99 b16a2
'99 b16a2, just rebuilt and dropped back in, wouldn't idle well (too low), mechanic adjusted the timing to 16 deg BTDC, and used the screw on the bottom of the throttle body to adjust idle up to 750 +/-....
Plugs/cap/rotor in good shape, air/fuel filters ok, evap system working properly, no CEL.
Now the engine idles perfectly when it's warmed up, but feels as if it's choking or getting too much fuel when at cold/fast idle, and doesn't drop down through fast idle the way it used to, if you tap the gas it bogs slightly then idle gets a little lumpy and feels like it wants to stall (but doesn't).
WHAT IS THE PROPER WAY TO ADJUST IDLE SPEED FOR THIS MOTOR???
all help appreciated.
thanks
Old Jul 18, 2008 | 11:46 AM
vtecb18c's Avatar
Default Re: idle problem, '99 b16a2 (twisted civic)
you may need a new TPS
Old Jul 19, 2008 | 11:09 AM
richcon82's Avatar
Try changing out the Idol Air Control "IAC"
PwrdByVtec_EM1
18
Oct 1, 2011 08:03 AM
twisted civic
Jul 17, 2008 08:08 PM
minner
Oct 8, 2006 01:30 PM
ex94vtec
14
May 6, 2006 02:07 AM
slamdunkcivic
Apr 11, 2005 10:32 AM
