d16y8 sluggish after rebuild
Old Oct 21, 2012 | 03:25 PM
Jay_Mills's Avatar
Icon2 d16y8 sluggish after rebuild
whats up ht enthusiast
i have a serious problem.. i just did a semi fresh rebuild on my d16y8 and the motor is super sluggish like something in or outside the motor is way to tight.. i did do crank and bearings both main and rod, and i didnt adjust valves on the head because it came str8 out of the car doing good. is there anyway who has had or has knowledge of this problem. i have people telling me that the timing belt is to tight but idk.. plz help..
Old Oct 22, 2012 | 04:50 PM
hybridmiklo's Avatar
Default Re: d16y8 sluggish after rebuild
check mechanical timing.
Old Oct 22, 2012 | 09:04 PM
Jay_Mills's Avatar
i did that.. but do you think i over tightened the main caps and the rods.. because i used one of those crappy needle torque wrench's im just lost.. i think imma pull the motor out tomorrow and just start from ground zero..
Old Oct 23, 2012 | 05:40 PM
no. if you did you would haver metal shavings in your oil.
Old Feb 8, 2013 | 04:43 PM
jae401's Avatar
Did you find out what the problem was?
Old Feb 8, 2013 | 04:53 PM
949's Avatar
949
i did this exact same mod to my d16a6.
whats is your block?
Old Feb 9, 2013 | 03:36 PM
BwoodEj1's Avatar
Try turning the dizzy over a bit. Timing could be a little off
Old Feb 10, 2013 | 05:38 AM
hondamark35's Avatar
what were your clearances on the main and rod bearings? did you check them?
have you checked the compression? does the motor sound normal?
go back and double check everything. if anything is out of spec, fix it and then check the drive-ability results. repeat until it's right.
Old Feb 10, 2013 | 08:21 AM
949's Avatar
949
oh **** didnt realize someone bumped an old thread. im sure he has fixed it by now.
Old Feb 12, 2013 | 08:57 PM
Jay_Mills's Avatar
lol sorry guys.. i didnt know you guys were still writing on this post but yes i did figure out the problem.. i dizzy was Fu**ed up and also after i figured out the dizzy was messed up.. i realized that the overall problem was the transmission and clutch.. the throwout bearing wasn't engaging or disengaging all the way so that's what was making the engine sluggish to a certain rpm.. also my valves were misadjusted from the last person who owned the head.. So all in all i had a whole slew of problems.. and after a week of driving the car i lost to much oil pass the rings and out the valves and ended up spinning a bearing.. soo now sadly the car is back in my back yard.. and its back to the drawing boards for me...
CplNet
Nov 24, 2014 03:11 PM
TripleLude
11
Aug 21, 2013 08:29 PM
ArtyTheKid
Dec 25, 2012 10:15 AM
bgdgman
Oct 22, 2006 05:48 PM
Trailz-EX
Oct 13, 2004 07:40 PM
