transmission to block strip tread help!
measure the bolt. Metric threads are easy. probably M14 X 1.5
Chase it out with a tap then with the proper bolt to get all the way to the bottom, make sure the bolt you use to mount is long enough to reach almost to the bottom of hole to get as much tread grabbing as possible.
I damage is bad, then I agree with hondamark35 get a treaded insert...
94
Thread Repair Using a TIME-SERT Insert - YouTube 94
I had to do this to my trans all three holes for like $20 good as new! Maybe even better
