Idling issues H22a
Old Mar 25, 2014 | 07:34 AM
DeeJHonda95's Avatar
Default Idling issues H22a
Have a h22 swap and when I try to start it on first key cycle it does nothing.. Then when I do second key cycle it starts if I give it some throttle.. Id like to get it to start on first crank but idk what to do.
Also when my engine is a operating temp the car will decide to stall out completely as rpms drop all the way to zero while I am in neutral. Sometimes is idles fine in neutral.. It sucks cuz I gotta press brake/ebrake and gas to keep it going when coming to stop.. I took apart FITV and IACV and cleaned both .. Still decides to fall on it's face randomly..
So my three questions basicly are..
Is the engine not getting enough air @ startup to crank over first key cycle?
Why is it idling off and on?
What may cause these things to happen?
Old Mar 25, 2014 | 02:16 PM
Nathan007's Avatar
Default Re: Idling issues H22a
you can check the TPS to make sure it's correctly calibrated (see factory manual)
I had idle issues with my obd2 f20b/h23 swaps, idle would jump from 1000 to 3000. Cleaning/adjusting IACV didnt change nothing. I got tired and blocked it off (while still connected) and made my own idle with the throttle stopper screw. The negative side is that i have no idle until my car is warm enough (~100 farenheit), then a shitty idle until it gets to operating temp. Better than nothing is what i branded that fix.
shaylude
Jul 12, 2007 04:33 AM
Maireeka
May 31, 2007 08:27 AM
GOTNOS
Nov 28, 2004 04:05 PM
accord-lude
Nov 15, 2004 11:01 PM
