96 civic CX B16a2 swap help!
I have put a b16a2 in my 96 civic cx, its a full swap and I went from automatic to manual. I have a knock sensor that I do not know which wire to use to hook up to the plug. I have 3 plugs and the knock sensor is a 1 wire, I do not know which wire to use and what to do with the other two; please advise. also with the crank sensor, do I need to hook that up? I am using a p72 ecu. if that helps? any information would be helpful thank you!
BrokenSyde
08-14-2012 05:04 PM
Civic Hx-T
01-30-2004 07:11 PM
hj
10-29-2003 04:40 PM
