more or less grease on prise axel
Old Aug 20, 2014 | 12:52 PM
joytjuhhhh's Avatar
Default more or less grease on prise axel
Hi guys
How much grease do i need to put on the axel on the gearbox that goes into the clutch ?
I also did some grease on the inside of the release bearing and the shaft.
Also a little in the ball joint in the clutch fork.
But i need some confirmation that its done good or bad seeing the picture below.
And tips are always welcome !
Thnx you hondafolks
Old Aug 22, 2014 | 12:07 AM
holmesnmanny's Avatar
Default Re: more or less grease on prise axel
Just a little bit on the input shaft threads.
Old Aug 22, 2014 | 02:01 PM
rudebwoy's Avatar
light to none.
I messed up a twin plate clutch a few years ago by putting too much grease on it which basically a really light coat. the grease ran down to the clutch plates and messed them up.
put a light coat on and wipe it off.
Old Aug 24, 2014 | 07:41 AM
joytjuhhhh's Avatar
Thnx for the answers.
I think i did a little to much grease on the axel.all between the splines are full of grease.
Schould i also pit some grease on the inside ring of the clutch ?
Greetz en thnx guys !
Old Aug 24, 2014 | 11:46 AM
rudebwoy's Avatar
when I install I usually use lite coat of lithium grease, on the bearing shaft, and on the tips of the fork really really lite.
where in Germany are you? ask me how I know?
Old Aug 25, 2014 | 03:24 AM
joytjuhhhh's Avatar
Hey rudebwoy !
Thnx for your replay !
I dont life in Germany ,but i think that you see the high temp grease haha
i life near Germany ,in the Netherlands !!
Old Aug 26, 2014 | 11:28 AM
rudebwoy's Avatar
Yep! grease tube.
do you know sneaky? and DP-engineering? I use Dp for tuning?
Old Aug 27, 2014 | 09:52 PM
VeeSykkz's Avatar
Clutch is a FRICTION assembly. keep lube of any sort to a bare minimum.
Old Aug 28, 2014 | 11:51 AM
rudebwoy's Avatar
none at all.
only put grease on the bearing shaft, very thin coat like when you lotion your hands.
Old Sep 1, 2014 | 10:14 AM
joytjuhhhh's Avatar
Thnx rudebwoy !
yess i know sneaky tuning !
and i heard of dp but dont know who that is
i did al little to none grease where the splines are (like you lotion your hands)
and i did it a little on the bearing shaft
do you mean the bearing shaft like where the bearing moves up and down when you press the clutch pedal ?
sorry for my bad engilish and i epriciete your help verry much !!!
Old Sep 1, 2014 | 11:08 AM
rudebwoy's Avatar
Thnx rudebwoy !
yes
lolv8s
K Series
Aug 23, 2015 12:50 PM
Super79Dave
17
Apr 22, 2011 07:46 PM
mikensu1
Apr 17, 2008 05:29 AM
maxogsr
Jun 22, 2005 06:46 PM
ALF
Feb 13, 2003 04:21 AM
