b16 swap poor/no acceration in vtec
Old Sep 15, 2014 | 05:30 PM
Dustin B's Avatar
Default b16 swap poor/no acceration in vtec
b16 swapped vx hatch, just got the swap running semi well. When I accelerate through the full rpm range it feels like it has no power, and once it gets past vtec crossover it accelerates even slower. it's like it's hitting a wall in the power band.. not sure if it's timing or misadjusted distributor.. any advice guys?
Old Sep 15, 2014 | 08:20 PM
Dustin B's Avatar
Default Re: b16 swap poor/no acceration in vtec
possibly catalytic converter? are d series fuel pressure regulators any different from b series?
Old Sep 15, 2014 | 10:16 PM
holmesnmanny's Avatar
Remove the oxygen sensor and run it. See if it runs better.
Old Sep 16, 2014 | 05:53 AM
Dustin B's Avatar
o2 was deleted and substituted on Neptune for my test run, could my firing order be wrong as well?
Old Sep 16, 2014 | 06:12 AM
JuggerNaut-CTR's Avatar
If your firing order was wrong it would barely start/run and would most likely kill the coil.
Old Sep 16, 2014 | 06:45 AM
Dustin B's Avatar
yeah I know these are kinda stupid questions considering the car runs,
Old Sep 16, 2014 | 04:57 PM
Dustin B's Avatar
bump
Old Sep 17, 2014 | 02:29 AM
HondaPartsHero's Avatar
Technical Hero
Did you check mechanical and ignition timing? Check engine light on?
Old Sep 27, 2014 | 03:22 AM
Dustin B's Avatar
it was my timing guys. intake cam off by a tooth and exhaust was off by a tooth and advanced a tic on the adjustable cam gears. always always always check the timing if you didn't do it yourself! thanks for the input!
category5 SI
Mar 14, 2010 04:45 PM
meallout
Jul 30, 2008 05:27 PM
No
May 8, 2005 07:12 AM
raleylund
Jul 11, 2004 10:42 AM
gvillehnut
Feb 4, 2003 08:14 AM
