D16y8 swap to y7 help!
Old Sep 10, 2014 | 10:35 AM
Ryan Williams's Avatar
Icon6 D16y8 swap to y7 help!
hey there,
My friend had a y8 in her 98 Honda civic si but it blew a head gasket and warped the head and block so she picked up a y7 and got it put in but put the y8 manifold on, when trying to run the y7 ecu it idles really low and is throwing CEL code 14 which I believe (from research) is IACV, now I know non-vtec cars have a 3 plug iac but her mani has a 2 plug do I repin the ecu side or do I find a non-vtec iac and plug and wire it up, also do I need to change any of the distributor wiring I was told y7 dizzys use different plugs than the y8s
thank you for you're time
Old Sep 10, 2014 | 02:59 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: D16y8 swap to y7 help!
You'll have to get the 3 wire IACV throttle body and wire that sensor into the harness and ecu.
Old Sep 12, 2014 | 06:54 AM
Awesome thank you very much ! I got a y7 tb I'm gonna put that on and jb weld the y8 Iavc holes
97Ek9Civic
Aug 4, 2011 02:21 AM
knightsef-eg
Apr 25, 2010 07:35 PM
96jdmciv
Oct 29, 2008 04:25 PM
jayjay0718
Jul 29, 2006 08:01 PM
HENRY
Jun 12, 2003 02:02 AM
