VTEC Solenoid Code 21 CEL...bad VSS connection?
I have awesome grounds all over the battery and engine, including one on the VTEC solenoid itself. I also did the classic VTEC solenoid check of putting it to a 12V battery, and it did indeed click everytime. Before I swapped the tranny, the CEL would come on only when the engine was cold normally, occassionally on long trips. It didn't come on the first week after the tranny swap. Now it comes on all the time, warm, cold, whatever. I was told to check the VSS plug, the car has a mechanical VSS, so where is this connection? I assume it's between the Instrument Panel and the ECU, so is it somewhere behind the dash?
It turns out the VTEC solenoid itself had an intermittent connection, hence the intermittent failures. I replaced it with another B-Series VTEC Solenoid, and everything is solved. The bad one still passes all the tests with the 12V battery, and the filter is clean.
Cyphear
Feb 4, 2013 11:03 PM
GI8U2racing
10
Oct 10, 2007 05:28 PM
Pr0ject93hb
Sep 14, 2007 09:50 AM
