Rolling w/out axles- bad??
Old Sep 18, 2007 | 07:51 AM
hatchling37's Avatar
Default Rolling w/out axles- bad??
How bad is it to remove the transmission and reconnect the suspension, then roll the car around on the hubs without the axles in there? How bad is it on the bearings? Or is it anything I should worry about if I'm not moving the car far (from in the shop to a tow dolly to my garage at home). Any help would be appreciated.
Old Sep 18, 2007 | 08:23 AM
King V's Avatar
Default Re: Rolling w/out axles- bad?? (hatchling37)
It's ok to do that, as long as you put tires on the car . The axles dont support any weight, thats what the hub/bearing is for. I would make sure the engine doesn't take a trip out from the engine bay though.
Old Sep 18, 2007 | 10:04 AM
Default Re: Rolling w/out axles- bad?? (200kCivicSI)
Cool, just thought I'd ask before I go ahead and do that. I was pretty sure, but I just wanted a second opinion. Thanks
Old Sep 18, 2007 | 03:11 PM
1g's Avatar
1g
ummm, im not sure where that guy gets his information but your hub is a press fit with the axle keeping everything tight, theres a reason there torqued to 126 ft/lbs.
dont roll it more than a few feet unless you REALLY have too. please dont listen to 200kCivicSI
Old Sep 18, 2007 | 04:46 PM
SIXTY's Avatar
Default Re: Rolling w/out axles- bad?? (1g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1g &raquo;</TD></TR><TR><TD CLASS="quote">ummm, im not sure where that guy gets his information but your hub is a press fit with the axle keeping everything tight, theres a reason there torqued to 126 ft/lbs.
This guy is right. If you have to move it around alot, i suggest at least using a bolt/washer combo to keep the hub from seperating. I found this out the hard way
Old Sep 19, 2007 | 04:12 AM
King V's Avatar
Default Re: Rolling w/out axles- bad?? (SIXTY)
Yeah, move it around alot. I was assuming it would be a little. Going from the shop to a tow dolly really isn't that far, people.
Modified by 200kCivicSI at 9:05 AM 9/19/2007
Old Sep 19, 2007 | 05:04 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 200kCivicSI &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, move it around alot. I was assuming it would be a little. Jeez, everyone likes to prove everyone else totally wrong on this whole forum....</TD></TR></TABLE>
Dude they're right, and this is a crucial peice of info to just act like you know.
Axle nuts are there to hold the hub together. if you have to, go to a junkyard, get some crap axles, cut the shafts right before the outer cv joint, and tighten those in there for now.
Old Sep 19, 2007 | 05:08 AM
King V's Avatar
Default Re: Rolling w/out axles- bad?? (mgags7)
Sorry for my ignorance. I didn't think moving a car to a tow dolly required the purchase of junk axles. I'll stash this away in the "dumb things i said" folder.
Old Sep 19, 2007 | 05:10 AM
mgags7's Avatar
1500lbs+ on press fit wheel bearings isn't exactly my idea of safe.
speaking of the word safe....that reminds me of something...ahh yes.."better safe than sorry"
Old Sep 19, 2007 | 05:13 AM
King V's Avatar
Default Re: (mgags7)
True, true.
jchrm80
Aug 30, 2009 06:27 PM
_ek9_Chri$_
Dec 9, 2008 08:33 PM
skunk2powered
Sep 4, 2004 02:09 PM
Todd Reid
11
Apr 19, 2004 12:56 PM
hybrid901
Jun 3, 2002 11:42 AM
