Possible Dumb question for Racing Transmissions
Old Sep 21, 2007 | 01:20 PM
^AnDre^'s Avatar
Default Possible Dumb question for Racing Transmissions
Not knowing too much about assebling transmissions but knowing a bit more about gear ratios. Without trying to explain too much, I am wondering is it possible to install a fourth gear as a fifth gear ? The 94-01 USDM LS 4th gear @ 0.966 with main teath count at 29 and counter ar 30 would be perfect acting as a fifth gear for my application, and it would reduce the cost of having some custom gears manufactured being an OEM gear. Is this possible?
Old Sep 22, 2007 | 06:24 AM
^AnDre^'s Avatar
Default Re: Possible Dumb question for Racing Transmissions (^AnDre^)
anyone?
Old Sep 22, 2007 | 05:08 PM
JDMAppeal's Avatar
no, the fourth gears dimensions, design and how it engages with the synchro are different from a 5th gear.
Old Sep 23, 2007 | 12:04 AM
slammed_93_hatch's Avatar
sure it is possible, the gears don't know what gear they are, but it depends on size.
IIRC bensen (the tranny guy) uses a 3 gear as a 2nd gear or something along those lines
Old Sep 23, 2007 | 08:20 PM
Bense's Avatar
Default Re: Possible Dumb question for Racing Transmissions (JDMAppeal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMAppeal &raquo;</TD></TR><TR><TD CLASS="quote">no, the fourth gears dimensions, design and how it engages with the synchro are different from a 5th gear.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">sure it is possible, the gears don't know what gear they are, but it depends on size.
IIRC bensen (the tranny guy) uses a 3 gear as a 2nd gear or something along those lines</TD></TR></TABLE>
I'm using a 3rd gear as 4th gear.
I'm not sure about b-series, but with d-series you can use a 3rd gear as a 4th gear. and you can use a 4th gear as a 3rd gear.
Old Sep 24, 2007 | 01:41 PM
^AnDre^'s Avatar
Default Re: Possible Dumb question for Racing Transmissions (Bense)
hmm... i guess some playing around might be in-line and hopefully it works on a b-series tranny. Would make my life alot easier and cheaper
Rickvanuden
Transmission & Drivetrain
Jun 8, 2017 09:00 AM
EK-Chris
Jan 13, 2005 09:35 PM
Jake
13
Mar 11, 2004 11:33 AM
