Does a D15B2 engine have LMA's?
Old Sep 15, 2007 | 10:35 PM
djnikko's Avatar
Default D15B2 possible rod knocking?
Ive just bought a '94 EG civic with a d15b2. I got it cheap due to bad knocking noise, the seller reckoned main bearings had gone after searching on here im leaning towards rod knock or bad LMA's (if this motor has them?!?). I was going to do an engine swap regardless but if I get this engine running ok it will be good for a while. How can I test for a bad LMA?
Also on a side note, can I fit a different d15 engine in this chassis using the same running gear? d15z6 maybe?
Much appreciated
Modified by djnikko at 3:43 AM 9/17/2007
Old Sep 16, 2007 | 12:32 AM
Redline130's Avatar
Default Re: Does a D15B2 engine have LMA's? (djnikko)
The D15B2 does not have LMA's. LMA's are only used on VTEC heads. You can use a D15B7, D15Z1, or any other D16 motor that you want to run. All will bolt up to your existing transmission.
Old Sep 16, 2007 | 06:41 AM
djnikko's Avatar
Default Re: Does a D15B2 engine have LMA's? (Redline130)
I have a noisey head and after reading here thought it would be a faulty/stuck LMA.
Any other idea's? Im about to pull the plug leads one by one to test for rod knocking
Cheers
Old Sep 16, 2007 | 12:03 PM
Redline130's Avatar
Have you done a valve adjustment lately?
Old Sep 16, 2007 | 06:42 PM
djnikko's Avatar
I did a valve adjustment yeah, I did a compression check also and that was alright too. Ive now taken the head off and found I could push the number 3 piston down a fraction with a screwdriver and it made a knocking noise as I did so. Ive started taking the oil pan off to have a deeper look. It looks like im gonna have to go with another engine as I need this car working in the few days. Is this sounding like rod knocking? It is hard to rotate the crank by hand when the 2 middle pistons are moving upward if that helps.
Is there any other engine that will bolt straight in the EG chassis using the same running gear that I have for the D15B2?
Cheers
llmercll
Honda Civic (2001 - 2005)
12
Jun 5, 2015 06:03 PM
farhan445
Nov 21, 2006 07:03 PM
stewdabaker
Feb 24, 2006 03:15 PM
Ri5e
May 25, 2003 12:57 PM
Mover
Apr 3, 2002 08:56 PM
