Help me with Radiator issues...
Old Dec 9, 2005 | 11:34 AM
B6tPoweredMx3's Avatar
Default Help me with Radiator issues...
Long story short, i bought a civic half core for my mx3 thought i measure it right, but as you can tell i got the length and the width mixed up. Dont ask how I just did.
Would i be able to turn it on its side? Would it still cool the same or would there be problems with the flow of the coolant.
Any other forseeable problems? Would i run into a problem with the coolant over flow/radiator cap?
Old Dec 9, 2005 | 01:11 PM
JimBlake's Avatar
Default Re: Help me with Radiator issues... (B6tPoweredMx3)
You may have trouble working the air bubbles out of the 'top'(?) tank of the radiator.
Old Dec 9, 2005 | 08:43 PM
EG2Driver's Avatar
Default Re: Help me with Radiator issues... (JimBlake)
there is also a bleed valve near the T-stat housing if u cant get rid of all the bubbles thru the rad cap
Old Dec 10, 2005 | 02:38 PM
b18ccivics's Avatar
Default Re: Help me with Radiator issues... (deadend9009)
couldnt you just get a remote mount filler on the upper radiator hose and run a really high pressure cap on the radiator and a lower one on the filler so if it vents off it will be the top one which would go to your expansion tank. Think this would work but i might be wrong.
Old Dec 10, 2005 | 03:52 PM
Default Re: Help me with Radiator issues... (b18ccivics)
Ive probably already got it sold, but i did figure out what would work, would require some custom work but could be done, to much work for a 130$ radiator.
Skeetzy
19
Nov 14, 2016 08:51 AM
__37__
Jul 7, 2003 05:58 PM
BluLuder
Jul 29, 2002 11:29 AM
EGh22aEG
Jan 9, 2002 06:37 PM
