Code 21 (VTEC Solenoid) clicking on, instead of VTEC engaging
Old Dec 16, 2005 | 11:18 AM
D-Rob's Avatar
Default Code 21 (VTEC Solenoid) clicking on, instead of VTEC engaging
Like the title says, there's no VTEC. It just throws a code 21.
Wiring was re-checked, and re-run, oil level is perfect, VTEC pressure switch is hooked up properly...
JDM B16A into '93 Civic with jdm P30 computer.
Old Dec 16, 2005 | 12:30 PM
JayDeMgsr's Avatar
Default Re: Code 21 (VTEC Solenoid) clicking on, instead of VTEC engaging (D-Rob)
try cleaning the little screen inside. i did it to mine when it started to crack late and it fixed it.
Old Dec 16, 2005 | 12:34 PM
D-Rob's Avatar
Default Re: Code 21 (jdm91integragsr)
Already tried cleaning the screen, and replacing the solenoid.
Old Dec 17, 2005 | 11:28 AM
infrontofu's Avatar
is the motor warm? becuase it has to be at a certain temp before it engages...
Old Dec 20, 2005 | 07:27 PM
93turbo16's Avatar
Default Re: (infrontofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infrontofu &raquo;</TD></TR><TR><TD CLASS="quote">is the motor warm? becuase it has to be at a certain temp before it engages... </TD></TR></TABLE>
yep, everything is warm, no other codes either.
Sounds to me like an ECU.
Old Dec 21, 2005 | 02:58 PM
93turbo16's Avatar
well it wasn't the ecu. The car has a huge vacuum leak, the intake manifold I believe is the source. Hopefully that fixes it.
Old Jan 12, 2006 | 06:17 PM
B18cHatch06's Avatar
Default Re: (93turbo16)
mine does the same ****..has code 21..b4 i just had tps code n it went away out of no where n i have a vtec code now instead..goes tttzz at 6K..no vtec sucks..let me knoe if you fix ur problem
keychild486
11
Apr 2, 2008 06:28 AM
ghettoSi
Jan 11, 2008 11:39 PM
slowr6
Mar 27, 2007 04:51 PM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
1.8EG-T
Mar 10, 2002 05:56 PM
