Injector/Resistor box problem WTF???
Old Aug 14, 2004 | 03:52 PM
b18c1civic95's Avatar
Default Injector/Resistor box problem WTF???
Ok here it goes....93 civic dx hatch with an h23vtec.P13 supposedly chipped ecu. I wired in the resistor box And it was a go. well then my number 1 injector goes. so i buy a set of dsm 390's, same injector goes. only this time the injetor resistance is fine, theres power at the shock tower harness.every injector measures the same for current and resistance all the same?? now as i understand there is always power at the injector and the ECU simply grounds the injector out to cycle correct?? i might try some inline resistors instead. Ill check back with the post i originally used to do the swap but what am i missing here??? I've searched several other places and came up with some troubleshoots but they're all variations of the same idea/method.
and yes im positive its not the injector because i switched the plugs around.
Im thinkin i can somehow check to see if the ecu is grounding properly.I would assume it would be to fast to see on a voltmeter...man wTF?? lol and it isnt even giving me a check engine light?? sometimes it'll even start working again.
the resistance is 7 on all but the one thats messed up and it reads 6
ANYONE???
Modified by b18c1civic95 at 5:15 PM 8/14/2004
Old Aug 15, 2004 | 12:23 PM
Default Re: Injector/Resistor box problem WTF??? (b18c1civic95)
bump
jspec - integra Ls
Dec 26, 2010 08:33 PM
CHRIS29
Jun 9, 2009 04:43 PM
mickey b16
May 26, 2009 04:02 PM
b18c1civic95
Aug 15, 2004 12:19 PM
Teglove2
May 30, 2004 08:04 PM
