Help with Gas Mileage problem...
Old Aug 12, 2004 | 04:24 PM
daLixz25's Avatar
Default Help with Gas Mileage problem...
So I just recently had my car serviced by Acura for a Emission Warranty Recall (replaced plugs, wires, distributor cap and rotor, changed oil, etc). I bought some Guaranteed to Pass fluid and Fuel Injector cleaner and put in my gas tank in preparation of passing my smog test for the 2nd time. The gas mileage after the service was drastically improved (got about 340 for one full tank).
Anyhow, I just took out my AEM CAI and replaced with stock airbox and new filter without the resonator. When I was removing the CAI, I remember nudging the distributor a few times but I didn't notice it move or anything. After I finished installing the stock airbox, gas mileage has been much poorer compared to immediately after the service.
I wasn't expecting my gas mileage to decrease upon putting in the stock airbox but it obviously is much worse. Any clues, ideas as to what the problem may be? I'm suspecting that my O2 sensor MAY be bad, but then again, just thinking of different reasons as to why the poor mileage.
Current MODS:
Stock Airbox with STP filter
JDM ITR 4-1
SMSP carsound cat
ITR exhaust
Old Aug 12, 2004 | 06:19 PM
suspendedHatch's Avatar
Default Re: Help with Gas Mileage problem... (daLixz25)
Reset the ECU.
Aftermarket intake will give you better mileage than the stock airbox, particularly if paired with a good header and properly sized cat back exhaust.
Old Aug 12, 2004 | 06:44 PM
daLixz25's Avatar
hmm...so maybe I should put my AEM back on...
I just read that resetting my ecu may do the trick. Thanks H-T
dicecivic94
Dec 31, 2012 06:21 AM
elmejor
Feb 29, 2008 04:43 PM
93civicsedan
11
Apr 20, 2005 02:49 PM
ActiveAero
Jul 3, 2003 11:27 AM
ActiveAero
Jul 1, 2003 01:54 PM
