What is the difference between the O2 sensor before the cat, and the O2 sensor after the cat?
Old Aug 11, 2004 | 06:54 AM
turbo Si's Avatar
Default What is the difference between the O2 sensor before the cat, and the O2 sensor after the cat?
What is the purpose of each one. Reason I ask is because i'm pretty sure I need to change one or both due to gas mileage. Is there one that that pertains to fuel than the other or what?
Thank's.
Old Aug 11, 2004 | 08:16 AM
JimBlake's Avatar
Default Re: What is the difference between the O2 sensor before the cat, and the O2 sensor after the cat? (t
The one before the cat is used by the ECU, to fine-tune the air/fuel ratio. The one after the cat is used to verify that the cat is actually present & working. I don't believe(?) the 2nd one is actually used for engine control. So I bet only the 1st one can be blamed for bad gas mileage. But there's a handful of other things that can cause bad mileage, too.
I don't know whether there's a real difference in the sensors themselves, other than the electrical plugs...
Old Aug 12, 2004 | 05:01 AM
turbo Si's Avatar
Thank you sir!
rjmq06
Sep 12, 2010 03:05 PM
Ra GS-R
Jul 31, 2007 02:04 PM
joshcivic00
Nov 11, 2005 10:49 PM
dohc-nyne
May 4, 2003 08:56 PM
d8168055
Mar 19, 2003 06:15 PM
