stripped rotor screws
Old Aug 13, 2004 | 08:17 AM
iwhichisme's Avatar
Default stripped rotor screws
Jsut wandering if anyone has any suggestion on how to remove these things. They are too stripped to use a impact driver. The only thing i can come up with, is to drill them out. Just wandering if there is a particular type of bit i can use to yeild faster results.
peace,
Old Aug 13, 2004 | 09:07 AM
timmy8151's Avatar
Default Re: stripped rotor screws (iwhichisme)
Craftsmen has a set of Screw-out bits meant for stripped screws,
Old Aug 13, 2004 | 09:28 AM
hAILO's Avatar
Take a dremel(sp?) and cut a slot on the top of it... then try your impact driver with a flat tip.
Old Aug 13, 2004 | 10:38 PM
_oemek_'s Avatar
take a small flat chisel and a hammer. and chisel it on the head at and angle and try to make it turn. usually works most of the time i do it.
Old Aug 14, 2004 | 12:29 AM
IVI's Avatar
IVI
Default Re: stripped rotor screws (hAILO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hAILO &raquo;</TD></TR><TR><TD CLASS="quote">Take a dremel(sp?) and cut a slot on the top of it... then try your impact driver with a flat tip.</TD></TR></TABLE>
if you had an impact driver how did you end up stripping them in the first place?
Old Aug 15, 2004 | 09:16 AM
vtekstorm's Avatar
Default Re: stripped rotor screws (IVI)
a chizel with a fine point and the ole trusty hammer
Old Aug 15, 2004 | 03:58 PM
turbohondask's Avatar
Default Re: stripped rotor screws (vtekstorm)
drill them out will a 9 ot 10 mm bit i dont know what that is in inch but drill right down the middle then the screw head should come off, after that take the rotor out and you can take the threaded parts of the screw off by hand
Old Aug 22, 2004 | 05:45 PM
92whiteSi's Avatar
jsut did it today, replace all 8 of em after the impact scredriver and the airgun wouldnt get it off, we just used a chisel and a hammer and hit it at the angle that would spin it out and it boogered them up, but they all came out
Old Sep 6, 2004 | 10:49 AM
Bimmer99's Avatar
Default Re: (92whiteSi)
if you are replacing the rotor just break it off then use vise grips to spin the screw out it's a lot safer than an impact driver cause with that you could mess up your distibutor shaft
Old Sep 6, 2004 | 01:48 PM
TrueUntilDeath.com's Avatar
Default Re: (Bimmer99)
are we talking about brake rotors or ignition rotor
Old Sep 6, 2004 | 03:42 PM
iwhichisme's Avatar
i found that simply drilling them out with some titanium bits, was the best option.
Old Sep 6, 2004 | 03:43 PM
iwhichisme's Avatar
Default Re: (GMR MM 012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GMR MM 012 &raquo;</TD></TR><TR><TD CLASS="quote">are we talking about brake rotors or ignition rotor</TD></TR></TABLE>
but since you asked. Do you have any pointers for those having problems with the ignition screw?
Old Sep 6, 2004 | 05:22 PM
Default Re: (iwhichisme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">
but since you asked. Do you have any pointers for those having problems with the ignition screw?</TD></TR></TABLE>
well, i broke my ignition screw! i over tighten it and the head broke off. so today i went over to my friends house and we used a 5/16th drill bit to drill a small hole and then we used a bolt extractor and it came right out without breaking the threads. he has a semi spare dizzy around and we just took out bolts that fit and we found one and used a dremel to cut it to size, when i put on the screw, i put a drop of lock tite on.
edit- this is what the screw looked like when i broke it.
smoovekriminal
Aug 17, 2007 05:03 PM
BringIT
Aug 12, 2007 09:31 PM
kuja396
15
Jun 3, 2007 10:18 AM
gophat
Jan 15, 2007 07:35 AM
toguemaster
May 30, 2006 11:07 PM
